what is the pbx version? is it running version 18.0.8.939?I noticed that in the dashboard when I set dynamic it remains in detecting?
wget -O temp_ip.txt https://discoverv4.3cx.com/getip && clear && echo && echo "Your public IP is :" && cat temp_ip.txt && echo && echo && rm temp_ip.txt
Seize the opportunity to run a new 3CX Firewall Checker test to confirm that the network is configured properly.Even though the traffic to stun.3cx.com was properly opened. I set the new IP, restarted the services and the record was automatically generated with the new IP address, thank you very much![]()
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
