Solved Change license email address and FQDN
George Ts
I have two questions regarding license key email address and FQD:
1. In my 3cx Web Management Console, under Dashboard-License i have an email address configured and i need to change it.
Editing the license and clicking on Refresh License Key does not actually change this email address.
How can I change this email address?
2. Also, my license key seems to be bound to a sepcific FQDN. Even if i reinstall 3cx Debian from scratch, this FQDN is restored. How can i change it?
I guess customer portal is the answer, just seeking for your advise on the right steps.
Thank you!
Provided that you're referring to the email address under "Settings >> License >> Registration Details" do note that this is the email the License Key is registered under. To change this you will need to access the Partner/Customer portal with the Account that owns this license and change it from there.
License Keys get bound to an FQDN upon deploying a 3CX Instance and will not get unbound unless done so manually from within the Partner/Customer Portal. You will again have to access the portal with the owner account or one that manages this License Key and release the FQDN from there.
Please note that this option is now available in the Customer Portal of each license so the end-users can change this information themselves.
In order to change this information please follow these steps:
* Login to the Customer Portal using the email address attached to the license key.
* Navigate to the”Keys” tab. Select the license key you would like to edit or transfer ownership by clicking on the “Click to Edit“ option.
* From there you can edit the customer information or you can click on “Transfer Ownership” – the button is located beneath the email field.
* Once you click on it a pop up will appear to confirm that you indeed would like to transfer ownership and the email address of the person you intend to transfer the ownership to.
That worked perfectly. Thanks a lot. This may be closed.
Reactions: ChrisC_3CX
Glad to see you got this sorted!
devo.it
