Solved Change logo in webclient
DaleT
Does anyone happen to know by chance if you can change the 3CX logo? I have this set up in Wavebox and have two extensions running at the same time. I would like to change the logo, if possible, to make it a little easier to tell which extension I am logged in as.
13514
Dont think they'd want to lose their TM.
You could change the theme to blue?
Perfect suggestion! Thanks!
Hi Dale,
You can also change the user picture of the extension under Settings > General
Hi Dale,
That's a great idea too! I have my business logo. But I like that idea! Thanks!
Reactions: JohnS_3CX
Hi Dale,
Between changing the theme and modify the profile pic... that will work! Thanks again!
13527
gmacinit
