Change Message for Call Back
Wintel
it is possible to modify the following Call Back message: "You have asked to be called back at the following number 12345566789, press * to confirm, press 0 to change the number to be called back, press # to cancel"
It is possible to insert a message such as: "You are on line with the DItta, you will be called back by the first available operator" and the call is closed.
You would have to modify these and replace then whenever there's a 3CX update as I think they'll be overwritten.
hughesdouglas
