change outbound caller ID
Thomas Six
Platinum Partner
We have a customer with agents who work for different deparments. When the work on monday, for examle, for department 1 they need to dial out with outbound caller ID 1 and on tuesday for example they work for department 2, they need to dial out with outbound caller ID 2. Is there a way that a user can change his outbound caller ID?
Or is there another way to solve this problem? The only other way that I know is with prefix and use another outbound rule and configure the caller ID in the outbound rule
The solution that you provided is the only way as from the PBX you cannot configure outbound calls with a daily schedule and different caller id per day.
Reactions: OlegR_3CX
Hi Thomas
We made this functionality in JEDWare, where you by rights define who is allowed to change a caller ID. We made it here to avoid the need for everyone's access to the 3CX Server itself and to lower the admin Support.
For more info, have a look here: https://jed-ware.com/predefined-caller-id-list/
EDIT: Sorry, I sent the wrong URL, here is the right one: https://jed-ware.com/change-caller-id/
As another alternative, take a look at our 3CX Caller ID tool. This tool provides a simple web interface where agents can select from a pre-defined list of outbound caller IDs. Agents can choose the desired ID by phone number or name. In your case, they would select the department name.
mazet
