Change SBC IP Address on Raspberry Pi
Mike Shintani
I would like to change the IP Address on eth0 of my Raspberry Pi SBC. Can I simply go into the sudo nmtui utility and make the change? Will I need to do any other configuration changes at my Hosted 3CX SBC profile screen, or any other place on the Raspberry Pi?
SBC can change its LAN IP it will take few minutes for SBC to reconnect to PBX, normally you have nothing to do on PBX side settings.
this is also possible to let SBC with DHCP and make a mac reservation adress on router side.
grahamaskew
