Change status name and order
dostro
New User
i would like to know if its possible to change the name of the status and how to remove a status from client view.
My client just needs "Available, Away and Vacation".. i know i can change the name of a status under settings->parameters but i dont know how to delete one.
Thanks in advance,
Dom
Okay thats great thanks for your answer.
But how do I remove statuses from the list?
Hi @dostro,
There is no way to remove statuses, they come with the PBX. There is no way to remove the status. DND is used by the system when autoswitching the PBX out of office hours and more, so it cannot be removed.
Sugu
