Change system extensions
Michael.Bang
I am setting up a PBX for a large client and they use extension 700 as the reception phone. Is there a way to change the system extension 700 (webmeeting bridge i think) to something else so i can use it as a user extension. This is a fresh install so using the latest version of 3cx installed onto windows.
Yes.
I'll just anticipate that you would like someone else to do the work for you and assume you want to know where to make change. So you don't have to look for it, is that correct?
You might look at conference settings.
