Danilo_Wyntech Bronze Partner Advanced Certified Joined Sep 23, 2019 Messages 2 Reaction score 0 Sep 23, 2019 #1 Hi, Please, how do I change the timezone of my 3CX linux server using putty for example?
SweetAction 3CX MVP Gold Partner Joined Jan 19, 2018 Messages 3,462 Reaction score 2,321 Sep 23, 2019 #2 Have you tried this yet? https://wiki.debian.org/TimeZoneChanges Although I am unsure why you care about changing that. 3CX uses it's own timezone settings (not from the OS), so as long as the time is consistent, you should be fine.
Danilo_Wyntech Bronze Partner Advanced Certified Joined Sep 23, 2019 Messages 2 Reaction score 0 Sep 23, 2019 #3 Thanks a lot! I only used the command "dpkg-reconfigure tzdata" The server was with timezone +03 and here in Brazil is -03. As a result, the Digital Receptionist was not routing the calls correctly. Now is OK. Thanks very much!
