Changing OpenAI - "gpt-4-turbo" to "gpt-4o"
pbxuser73
We'd like to use gpt-4o from gpt-4-turbo. Is there a setting to set which model we can use?
Check the screenshots. This is how you can change from gpt-4-turbo to gpt-4o.
The cost is half.
  • Haha
Reactions: pbxuser73
It does not look like OPENAI_MODEL change helps.
Any updates on this.
The changes I mentioned earlier worked for me. I also noticed on the OpenAI platform that it uses GPT-4o in the usage section.
Just to confirm. Is this hwo this should look?
and
Yes this looks correct.
It actually worked. It just takes a few minutes to get it to show up.
Also there is gpt-4o-mini (OpenAI released it today) which cost even less. Maybe you can try it.
amazingbv
