Changing the Phone Ring Volume of Fanvil X6 via 3CX Provisioning Template
Michael Schönburg
Gold Partner
how can I change the phone ring volume via 3CX provisioning template? I haven't found the fitting property in the 3cx provisioning table yet. In the phones config it is the "HandFree Ring Vol"-Property that changes the phones ring volume. I have tried changing the "<HandFree_Vol>" which can be found inside the "DSP_CONFIG_MODULE" by default and didn't change the "HandFree Ring Vol" value in the phones config. I have also tried manually adding the line "<HandFree_Ring_Vol>2</HandFree_Ring_Vol>" or "<HandFreeRingVol>2</HandFreeRingVol>" under the line "<HandFree_Vol>" inside the "DSP_CONFIG_MODULE" which also didn't work.
What do I need to change in the 3CX provisioning template to change the phones ring volume?
I am looking forward to your comments.
Best Regards,
Michael Schönburg
