Solved Chrome PWA: Unable to answer call using the pop up
bit101
Hi together,
unfortunately we faced with the same issue like in this topic:
We are using Chrome Version 133.0.6943.127 (newest version today) with Windows 10 Pro x64.
So the notification in Windows appears but when we click on the green button the call will not picked up and the PWA windows will not open.
Does anyone faced with the same issue with the newest Chrome version?
regards
We are using Chrome VErsion Version 133.0.6943.142 with Win 11 Enterprise x64
Same issue, call can not be picked up from the notification window.
Chrome Version 133.0.6943.142 (Official Build) (64-bit)
Windows 10/11 PRO
3cx v20.4
Same problem.
Microsoft Edge pwa is working.
Any news about this bug?
This issue is currently under review. We will let you know once we have any updates on this.
@bit101 @Ines Wild if you upgrade to 134.0.6998.36 on Chrome, do you have the same issue?
Reactions: bit101
134.0.6998.36: now is working
with 134.0.6998.36 it works again :)
Jake_Southern
