CID Inbound Rule - Multiple Numbers
greatchoice
Is there a way to make 1 rule with multiple CIDs?
Hi @greatchoice,
Yes, if you create a CID rule and separate your Caller IDs by a comma, the PBX will run the rule correctly. Example below:
This also works with wildcards:
florentrobineau
