CID Routing not working
greatchoice
I have a gate that when pressed for assistance is supposed to call the main number. However I need that caller ID rerouted to an extension.
It shows the caller ID number which is copied and a CID route is made matching but it continues to go to the main IVR.
I had this setup in Free PBX and it worked great. Am i missing a settings?
Does the 3CX Activity Log provide any clues as to why?
No logs for the calls show. It just routes to the IVR.
Only thing i can see if that the main trunk number in the trunks is setup to route to the IVR. But i just realized that the CID is below the main number. So that may be the issue
Yes, your CID rules should be above DID ones.
hughesdouglas
