Cisco 7925 Replacement for 3CX
DTI Tech
I have a client that has a number of Cisco 7925 WiFi phones in their environment. We are quoting them a 3CX solution but need to find a replacement to this particular phone. I looked through the supported device list and don't see anything other than DECT devices. Anyone have recommendations on a portable WiFi phone that will work with 3CX, even if its not officially supported?
Also, I realize the Softphone app should suffice. However the client specifically requested a dedicated WiFi phone.
I appreciate the assistance!
Hello @DTI Tech
Please note that in our current list of supported providers there are no WiFi IP phones. You can have a look at the supported IP phone list here: https://www.3cx.com/sip-phones/
There are a number of WiFi devices out there and if they are using SIP they should work with the system. There are also WiFi dongles for some supported devices, but please note that these are not supported by 3CX as all tests were done through Ethernet. If you face any issues with the device you will need to revert to a supported configuration before we can provider assistance.
WagnerFT
