Cisco SPA-301G
steve.davidson
SOHO User
I need a small wall mounted IP Phone compatible with 3CX v15.5. The Cisco SPA-301G is the perfect size for the location. Does anyone know whether it will work with 3CX and if so, what phone model I should use for provisioning as this specific IP Phone is not listed.
As the phone is not on the supported list. you could try manually provisioning the phone (you will not be able to provision it thru 3CX)
Search the forum to see if anyone has managed it
I've search but as yet, no one appears to have posted a way of provisioning the phone.
As @Saqqara mentioned you have to setup the phone manually. Provisioning is not possible.
A SPA-301G with f/w 7.6.1 is running fine on a 3CX v15.5 SP6.
That’s great. Thanks very much for all your help.
Thanks very helpful.
K7oR0x
