CISCO SPA502G
ivancc
Hello @ivancc
Please note that Cisco phones cannot be provisioned as remote extensions as clearly stated in guide you posted under the limitations section.
I would recommend using a support model from our supported devices list https://www.3cx.com/sip-phones/ or create VPN connection so that the phones appear as local to the PBX.
Where i can find a guide to setup this phone with VPN ?
If you use VPN, then, in essence, the phone is on the local LAN.
The network administrator should be able to establish a VPN connection between the remote site and the PBX. This is part of the network configuration so there are no available guides from 3CX.
johnblackwood1
