- Joined
- Apr 24, 2018
- Messages
- 2
- Reaction score
- 0
Is there a way to determine which plugins if any have loaded in the 3CX client?
The documentation around where to add an entry to 3CXClickToCall.exe.config is missing information on where in the file to add it. App config files have a very specific XML structure. My default client file is very sparse:
Another user had also posted that the example entry in the documentation is wrong and that it should be:
Thank you for the assistance.
Code:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<startup>
<supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5.1"/>
</startup>
</configuration>
Code:
<add key="MyClassName" value="MyClassName, My.Assembly.Name" />
