clipboard dialing
vinchu
hello
I have a client want to use the windows voip software to dial out on voip desk phone, also the clipboard needs to support the dailer.
which desk phone can support this feature? and any pointers for the setup?
I don't really catch your need. What about supported IP phones ?
Hi @vinchu
You need a supported deskphone, and the 3CX Windows or 3CX Webclient working in CTI/CSTA mode.
Then you simply dial in the app and the deskphone makes the call
If you have one to test, we can tell you how to switch to CTI or CSTA mode.
As for the clipboard there is no special support, you either paste the number into the 3CX client or you find software that will do the dialling for you.
travislogixal
