clock function / language of voice directives
Michael37
I want to put the alarm clock function in French but I can't do it.
When I created the digital answering machine I selected the language of the voice directives "French prompt set".
Could you help me please ?
Hi @Michael37,
Yes, this is correct. As per the guide: https://www.3cx.com/docs/installing-hotel-pbx/
"The Wake up calls uses prompts that are played to create and schedule wake up calls. 3CX Ships these prompts in English Only. Hoteliers will definitely need to play prompts in their native language. You can simply record the prompts in your native language and replace the existing prompts making sure to keep the format and the file names identical."
Jacob.Ive
