CLOUD Manual Yealink setup
deekay
Forum User
Can anyone guide me please - have just signed up for trying the CLOUD based 3CX but, for this trial, will be using 2 or 3 Yealink T26's which will need manual configuration
I hoped all I would have to do is change the SIP Server 1Host IP address (local windowds pc) to the IP address gerated with the CLOUD installation
Thank yu Kevin
Register Status Registered
Line Active Enabled
Label C3 Louise
Display Name C3 Louise
Register Name Rhee92HWgP
User Name 210
Password *******
Enable Outbound Proxy Server
Disabled
Outbound Proxy Server Port 5060
Transport UDP
NAT Disabled
STUN Server
STUN Server Port Port 3478
SIP Server 1
Server Host 192.168.1.112
Port 5060
Server Expires 3600
Server Retry Counts 3
SIP Server 2
Server Host
Port
5060
Server Expires 3600
Ah thank you. Thought that as the T26 were end of lfe there wasn't a provisioning template - i'll have a go. Much appreciated
Just keep in mind that there is a limitation with the T26
https://www.3cx.com/sip-phones/yealink-t20p-t22p-t26p-t28p/#h.e2e9dlym4hi8
You may need to go to your PBX Settings > Security and disable SSL/SecureSIP Transport and Ciphers
Otherwise when the phone tries to reach the PBX on HTTPS to get the provisioning config, it will not be able to negotiate a secure connection and provisioning will fail.
Ensure that the phone uses the specific firmware that we have here otherwise it may not be able to do HTTPS at all https://www.3cx.com/support/phone-firmwares/
Thank you John. I'll keep that n mind. I found a T23G while looking for the T26 so I started with that one and, despite one or two hiccups made a successful connection to the Cloud. Much appreciate the replies i've had.
Kevin
Reactions: JohnS_3CX
3K8iMGWviZ
