Codec gestion like ip phone for DECT ?
KoesioOccitanieTech
Platinum Partner
We are able to change codecs order on IP phone but when it comes to DECT, we don't have the choice, i'm pretty sure it was the case in V18.
I'm in Europe and PCMA is largely used here and my W90B use PCMU by default.
If we can avoid any transcoding it will be nice to have the choice of the codec order.
Can you explain me why it gets removed ?
Thank you,
Best Regards.
full ack, always the default PCMU problem - as with the fax :(
Look for a 3CX parameter named MLTACC_<MAC> . This specifies the order of codecs to be used for the DECT device.
Depending on the device, this is either plain text or a number: Codec 8 is PCMA, 0 is PCMU, 9 is G722, 18 is G729, etc.
no :(
Reactions: KoesioOccitanieTech
no :(
Oh nice, thank you for the fast reply.
If i change the parameter with the "MLTACC" and re-provision the DECT base, it should be good ?
RJenkinsROCK
