- Joined
- Jan 6, 2017
- Messages
- 25
- Reaction score
- 8
I'm using the Call Control API to create new extensions. Recently, extensions are now being created with no codecs assigned to them. Additionally, since 15.5 SP6, the web password is warning it's underlength.
Looking at the CreateExtension Method in the API there are no properties for setting the codecs or the web password. I can get the codecs using getCodecs but I can't work out how I can apply these to a new or existing extension (if they're missing) without using the GUI.
It looks like the API hasn't been updated to incorporate these new settings. The CHM for the API certainly hasn't, but the DLL doesn't seem to contain anything useful either.
Is there a workaround for these? Why are the default codecs set in the params for internal/external calls not being applied to new accounts which are created via the API - seems a bit of an oversight?
Any help would be very gratefully received.
