Command line tools to control 3cx?
goncal
is it possible to control aspects of the 3cx pbx from the command line or API calls? I am specifically looking for ways to enable or disable trunks from a script. It would also be useful to check the status of trunks and extensions.
I am currently running Standard Annual version 18.0 (Build 450) running on-prem on Debian 10.
Thanks in advance!
there are no such commands or api commands
i believe api commands are still on the roadmap - if and when nobody knowns
Thanks in advance!
Well the 3CX Management Console use there own API. I recommend to take an look at your browser DevTools and then the Network tab and search for "api".
gmacinit
