Commit failed on transaction Save Wparkextension.143 - System extensions registration and error
BrettTPF
Greetings all,
We're running 3CX 16.0.910 on Debian, on-premise. We are currently migrating from Elastix 2 and installed our virtual appliance using the migration tool that exported all our PBX configuration from Elastix about a year ago. For the most part all has been well with the system except that the system extension *1 (Call Parking) wasn't registering. I tracked it down to the default dial codes in Settings had been changed based on the Elastix codes during the import. Our setting for "Pick up a parked call" was set to *85.
I manually set all the dial codes back to the default values, but when I changed 85 back to *1 the management console displayed a pop up with the error "Commit failed on transaction Save Wparkextension.143 - '1'", which I can only presume is telling me that changing the field in the DB failed.
12116
Oddly, the system extension *1 now shows registered, but *85 is still appearing in the list and shows Unregistered. I would like to make *85 disappear and then all would be well.
12115
Anyone have any suggestions on how I might hack this and get *85 removed from the DB without borking the whole thing?
Phones are Yealink/Snom, no custom templates, firewall checker is happy, one Twilio SIP trunk and a bridge to Elastix.
Thanks and cheers!
B.
Hi, datas direct access is not recommended at all or granted by 3cx , probably you need to open a support ticket to expose 3CX staff your need to remove this in database.
Many thanks for the reply! I was kinda afraid that would be the case. I was hoping there might be a quick and easy fix.
Cheers,
B.
perhaps more experienced than me on your specific need can advice something else to do, my way is 3CX supported
Reactions: BrettTPF
bosdorf
