Computer Not receiving IP
MPH2020
Forum User
After i upgrade the GXP2160 for the latest version the PC is not receiving IP address .
The computer is connected from the PC LAN Port of the Phone .
If any one can help me .
What version is considered the latest version? Perhaps you can share some more specific information.
the version is 1.0.8.56 of GXP2160
Start by upgrading then use the 3CX template. It will configure the necessary settings for the PC port (required since 1.0.9.x).
Can i do it manually to upgrade it to 1.0.9.X .
After upgrading 1.0.9.X the issue will be solved or do i need to do some other settings from the phone
3K8iMGWviZ
