Conference Call PIN doesn't work for organizer or invitees
Vitamin V
Gold Partner
Just updated a few instances to version 16.5 yesterday and today, including a new PBX Express instance in Azure Cloud. Found out on a schedule conference call today that the PIN number generated by our CEO wouldn't work. He mentioned this has happened 3 times now when he creates a conference call. I tried to join the conference and got the same message.
Looking at the Settings > Conferencing > Audio Tab:
Under Options there is "Require an organizer to enter a Conference PIN in order to create conferences from your IP Phone" I see that is Enabled by default and a random number is generated each time its turned back on.
Turned it back on and testing this on a conference call I scheduled, I didn't get any announcement on inputting this option number vs. the PIN I generated for my test conference call.
Also saw this is on client's 16.4.504 instance as well.
So it has been an option for awhile?
Leave it on or turn off?
Bluebox Global
