Configurar un VTO2111DWP de Dahua
haaaquinquin
Trainee Partner
Para saber si alguien a podido configurar unVTO2111DWP de dahua como extension?
This device is not supported so it is unknown if it can work with 3CX.
I would suggest to contact the seller or manufacturer to get help, or instead use one of the supported doorphones from this list: https://www.3cx.com/sip-phones/
IP: server IP
Port: 5060
Username: ext number
Password: (blank)
SIP Domain: (blank)
SIP Username: auth user
SIP Password: auth pass
Try that.
Gracias Frederick Tengo el VTO con el proveedor ya que reclame garantia. En cuanto me lo devuelva probare la configuracion que me mencionas
IP: server IP
Port: 5060
Password: (blank)
SIP Domain: (blank)
Try that.
Hola, ya lo intente pero no funciono, me arroja este error
I tryed but not work
30/03/2021 10:03:36 - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.100.231:5060 tid=1777751369 [email protected]: REGISTER sip:192.168.100.244 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.231:5060;rport=5060;branch=z9hG4bK1777751369
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>
Call-ID: [email protected]
CSeq: 6 REGISTER
Expires: 60
Proxy-Authorization: Digest username="2002",realm="3CXPhoneSystem",nonce="414d535960634bd707:668b3cd52505760aea650791788bbc55",uri="sip:192.168.100.244",response="ee80856a76c956f45ae09723f598d8bf",algorithm=MD5
User-Agent: Dahua UAC/3.0 VTO2111D V4.300.0.7
PhoneState: 0 Content-Length: 0 ;
Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Max-Forwards: 70
CSeq: 6 REGISTER
Expires: 60
Hey, did found a solution for that? I also have Dahua VTO 2111g-wp and trying to set it up. but no success yet
Hello, No, nothing solution :,(
Reactions: GP1noMendez
Finatra.us
