Solved Configure Office Hours Not Available
king1
New User
I'm trying to change the office hours for a Lightsail hosted 16.0.4 3cx install. When I go to Settings -> Timezone, Office Hours, & Holidays I can see the blue link to modify the default hours. But when the pop-up shows and I change the hours, the "OK" button remains grayed out. I have tried different browsers with the same result. Any ideas?
In case anyone else needs this, I figured out that it works if I hit the Delete button and then go back in to configure it.
Yep, you can't edit. Been that way for a while and still annoying
Kayla Norris
