Configuring Algo with 3CX
Alvin C
We are in the process of moving a client to 3CX. Just noticed they have more than 10 x Algo speaker in their premises which is connected to the old pabx system. Can someone provide assistance on how to auto or manually configure the algo devices with 3CX hosted solution.
Kindly note that no support can be provided with untested unsupported devices and can only suggest using only supported devices with 3CX to avoid issues. See supported devices here.
Reactions: CentrexJ
It is unfortunate that none of the Algo product line is supported when there seems to be so much demand for it AND none of the supported products that I can see provide outdoor paging functionality. The Grandstream device seems to be indoor only.
Car lots, restaurants, warehouses, amusement parks, etc all need outside paging solutions and the vendor makes quality products.
Offically supported or not, Algo works as it's a SIP device. Register it like any other SIP device. It's also the primary device we install - they rock.
You could write your own template if you want. I cannot share mine unfortunately.
mazet
