Connect same agent next call, its possible ?
bumblebeey
hi, we are using queue our pbx. if caller connect queue again connect direct last connected agent, its possible ?
This capability is not built into 3CX. This question gets asked frequently. Perhaps I can offer a solution, but be aware this would require custom programming.
Since we do not have a way of customizing how queues route calls (beyond the polling strategy), we will have to make the routing decisions BEFORE routing the call to a queue.
There are two applications needed: (1) a service that monitors and records in a database the last agent that answered a call from the caller, and (2) a Call Flow Designer (CFD) that either routes the call to the previous agent or forwards the call to a queue.
The CFD would be placed in front of the queue. The CFD would need to look up in the database whether there is an entry for the Caller ID Number. If an entry is found, it would need to check the availability of the agent (logged into the queue, presence is available, and not currently in a call). If the agent is available, the CFD would route the call to the agent. If the agent is not available, it would route to the queue.
I have always thought an expiration date would be appropriate for database entries. For example, if it had been more than a year since the person had called, then perhaps sending the call back to the same agent would not be necessary.
thank you for your information. did you make any cfd apps about that ? can you help me ?
I have put considerable thought into what would be required, but I've not actually built this solution yet. However, we build custom solutions all the time and certainly could build this for you.
I could see yet another requirement. You might have the same agent servicing multiple queues. We might also want to record which agent answered the call for a specific queue.
Given that this question gets asked frequently, it's probably time we build a solution. We can help!
thank you @voiptoys i will talk with my manager and i will turn you with P/M,
this is necessary feature for pbx systems. I don't understand how 3cx skipped this
business@brightwaylogisti
