Connect Wise Pop On Answer
Rhys Haskell
Is it possible to set connect wise to pop on answer rather than pop on ring as it does by default?
Thanks,
Rhys
Hello Rhys,
Unfortunately that's not possible at the moment. The popup is launched when the extension rings.
You can disable the automatic popup, from the 3CX Web Client > Settings > Integration > Off. And then, when you receive the call, you can press the following button to open the contact record:
12403
Kind regards.
Reactions: accentlogic
Hello Rhys,
Kind regards.
Is this already on the development list or is it worth creating a post in the ideas forum.
I'm not aware of this being developed, so I would go to the Ideas forum....
lastshadow
