Connection timed out
Phil OE
I am getting connection timed out errors when in the email section to direct voicemail to email and sending 911 notifications. I have not changed anything on the smtp server, as well when I do a test it delivers.
Are you using a custom SMTP server?
Have you tried to send a test email and send it to the affected user email ?
It is pretty clear that 3CX cannot communicate with the SMTP server. We are all curious whether you are using the 3CX SMTP server or a custom SMTP server.
If this was a authentication issue you would get a different error. It could be a network problem, or a DNS resolution problem, or a SMTP server problem, but what is clear is that 3CX cannot connect to the configured SMTP server.
We are using the 3cx smtp server.
Is your license active in 3CX? What version+update/build are you on?
License is active until june 23 of this year. Build is 20 update 4.
x1515
