Connectwise integration with 2FA
bnelson
Seems like my integration with Connectwise is broke, and I beleive its because we now have 2FA enabled for Connectwise. Anyone know how to fix that? im getting this error when testing the integration:
Server returned a non successful status code - HTTPStatusCode=Unauthorized - Reason=Unauthorized - Content={ "code": "Unauthorized", "message": "Incorrect or disabled client ID" }
Hello @bnelson,
Having 2FA enabled should not be a problem, because the integration uses an API Key to login.
The error seems to be the missing Client ID. Please follow our guide to create and configure this Client ID. Please also note that shortly we will be providing this Client ID ourselves, so you don't need to create it. We will release an update to the integration soon regarding this. But meanwhile, if you need to get this working immediately, you will need to create this Client ID.
Kind regards.
Themarketmindset
