Console locked out or something else?
benf
We have console restrictions on all our systems. For some reason one system was saying invalid user/pass/mfa , we reset the password, it asks for new MFA but then says invalid code. So I am thinking either 1 - the time is off on the vm itself (doubtful but i have console access to test) or 2 - somehow console restrictions isn't working properly
Since it just says invalid login, and now invalid code on MFA, would anyone happen to know if I would get that on a console restriction as well? I thought I recall seeing a different message in the past like 'your ip not authorized'
So if the time isn't off then I cant think of what else to do.
Edit: Time was off by 18 minutes. Which is odd since this is cloud based that it hasn't synced time at all.
I consoled in and run the date commands
date --set 1998-11-02
date --set 21:08:00
Where is the pbx installed? Did you installed ntp correctly?
It was iso image in vultr, 3cx v20 is an option. I made a ticket to have one of my techs go through and check/confirm ntp is running properly on all consoles. It's the first time we've seen it and since it just said invalid login kind of threw us off.
swegner
