Contact lookup problem
dlr
New User
new to 3cx we're trying to make a custom CRM integration but the test button always produce the same response, "CRM Integration is working OK but contact number does not exist. Check log for more info or try a different number.".
Can anyone help us ?
Regards
Here is the answer shown after pressing "test" button :
Started scenario with empty id
Request text: XXXXX
Response text: {
"id": 34,
"firstname": "firstname",
"lastname": "lasname",
"profile": "XXX"
Response finished
Finished scenario with empty id
Our conf file is attached.
Regards
Request text: XXXXX
Response text: {
"id": 34,
"profile": "XXX"
Response finished
after testing we found that a rule for id was missing in our conf file.
Code:
<Rule Type="Any">id</Rule>
Problem solved
Regards
lastshadow
