Contacts from ODBC source - TTL ignored
maxmino
Forum User
I've configured ODBC connector in order to retrieve my contacts from SQL DB, the import works correctly.
If my data changes on SQL DB I need to reimport the contact.
I've set TTL value on ODBC to 1, I'm expected that the contact expires after 1 day, so I will able to reimport it from DB with the correct values.
After a few days the contact remain active, TTL value is ignored.
What am I doing wrong?
Regards,
Massimo
