Contacts Importer
alivoip
The Phonebook bulk-import is silently failing on our V20 Hosted instance
Steps to reproduce:
• Log in as a System Owner / Global Admin user
• Admin → System → Phonebook → top-right dropdown → "Company phonebook"
• Import any CSV — including a 1-row file in your own exact 14-column export format
• Result: modal "Import failed — No changes have been applied", no error details, importCount: 0
The underlying API call (POST /xapi/v1/Contacts/Pbx.ImportContacts) returns HTTP 200 with {"success":true,"importCount":0,"ErrorLines":[],"WarningLines":[],"Exception":null} regardless of file content.
Is there a permission or other setting causing this not to work?
Hello, is the file format you tried to import was based on an export coming from 3CX pbx?
if not , try to register one phonebook entry in 3CX console and then export the phonebook file and modify before re-import
You may also check the guideline here for more information.
Solution
Please paste an example file that replicates the issue. The response you are getting indicates that the importer found nothing to import.
ARKC
