Continue call to extension that has DID attached using Call Flow Designer
controlshift
Forum User
I would like the following scenario in 3cx V16
Call arrives at DID --> Call flows to Call Flow App --> Call continues to extension that has the original DID attached.
The reason is because I would like to have an intro prompt played at the start of all DID's (all of our staff have Direct in dials).
Is there a variable for the extension that is associated with the inbound DID?
I would like the following in Call Flow Designer
Call arrives
Play intro prompt
Forward to extension inside did.png (attached)
Thanks,
Hello @controlshift
You will need to create a CFD app that retrieves the DID called and plays a prompt depending on that DID. You can then send the call to the assigned extension.
For more details i would recommend creating a thread to the Call Flow Designer section of the forum.
hughesdouglas
