Solved Convert any +-sign calls to 00
d4-maertzdorf
Forum User
So I have setup a new V18 3CX phone system.
Inbound: OK
Outbound: OK (but only if I call using local numer e.g. 010 123 1212 (or 06 1234 1234) If I use international +-sign nummer e.g. +31 10 123 1212 (or +31 6 1234 1234), it does not dial
If I call 0031 10 123 12 12 (or 0031 6 1234 1234) it does dial just fine.
What is the setting to generall just replace the + with 00
https://www.3cx.com/blog/voip-howto/outbound-rules-a-complete-example/ Is what I found.
Does
+31 6 1234 1234 count as 11 numers (and 12 digits?)
I need a rule that would make +31 6 1234 1234 --> 0031 6 1234 1234 and if +32 6 1234 1234 is called it is 0032 6 1234 1234
e.g. any +xx(x) country code to be converted to 00xx(x)
Yeah, For some reason
The following does not work:
Process E164 Numbers --> Checked + Remove if same Country also checked
The following seems to work:
Process E164 Numbers --> Checked + Remove if same Country --> unchecked.
International Dial code: 00
Area code: blank
National Code: blank
Add prefix: blank
Managed to sort it by leaving the remove if same country and set the add prefix "+"
Reactions: NickD_3CX
Bluebox Global
