Solved Copy Meeting Link Grayed Out
neville
Gold Partner
On one of the systems I manage, the copy meeting link is grayed out when starting a webmeeting. If I schedule a meeting and join the meeting, the link works.
Hi @neville
Can you give a detailed, step by step way of how you start the meeting?
When I am in my webclient, I click WebMeeting and log in to start the meeting. The link is always greyed out. I have tried this on multiple machines, from both the latest version or Chrome and the new Microsoft Edge.
If you click the Invite Participants icon, can you get a link there?
If you first create a meeting, then go to it and add a user, the link is there and you can copy it. If you do not create a meeting, but log in to WebMeeting in the web client, there is no link when adding a user.
I experience the same.
If you enable the parameter "Requires you to connect to meeting first " , Everything will be as JohnS_3CX said.
Paurus, this was the answer. Thanks and be safe.
Chuck
Graham Robertson
