Solved Correct Procedure to Reboot Server Debian v18
ipt_dude
Hello Internets,
I get that 3CX is so stable that the MC doesn't have a option to "reboot server" - but I think that should be an option. Is the attached process an acceptable way to initiate a server reboot ? Also, once inside the terminal, what command should I use to exit the terminal session? Nothing I've tried has worked. Do I just kill the tab?
I always use the reboot command within the terminal screen
To close the terminal , I just close the browser tab
Saqqara to the rescue again. Thank you !
Reactions: ChrisC_3CX
ARKC
