correct time on ip phones
real_magiz
Dear all
our local time zone is GMT+6:30, Our Elastix server is not connected to internet most of the time because internet is so slow.
I would like to configure all ip phones should get correct time from Elastix server. If Elastix do not have enough good internet from time server, it should read from BIOS and set times to all IP PHones, if server and all phones are rebooted the next days, time should be correct .
any help using GUI of elastix or NTP.conf to fit that requirement?
try to install NTP server
Ntp has been installed on Elastix by default. How to configure so that all ip phones will receive correct time from it? Only elastix 4 has end point configurator btw.
http://www.cyberciti.biz/faq/rhel-fedor ... nt-server/
Above is a tutorial on configuring NTP on Centos. If your phones asre not supported by endpoint manager or you don't have endpoint manager, you will have to reconfigure each phone MANUALLY to get the time from your Elastix server.
CLTedu
