Could this be possible?
killmasta93
I was wondering if someone could clear somethings out for me or maybe tell me if its possible with the hardware?
What im trying to accomplish is
when someone calls my home line (317-xx-xx) gets an IVR and tells to either wait or if you know the ext that part I got.
The part where gets tricky is I have 4 ext and the 4 users have zoiper on their android or iphone so they can receive the call. But sometimes they dont hear the zoiper app or have bad data connection.
What I would want to do that if they do not pick up zoiper using something like misc destination to call their direct cell number.
I also have a spare dinstar GSM gateway DWG2000-1G-V211 maybe use that as a second trunk to call the cellphones without occupying my home line?
See pics for network structure
Thank you
yes its possible you can configure the followme app to do that.
Thank you for the reply,
So I could another trunk with my dinstar to call the cellphones?
ex:
call from home line---------to trunk home-----IVR--------then follow me uses the trunk Dinstar GSM to call the cellphones?
Thank you
Thank you for the reply you will you posted how it goes
Thank you
RRusev
