create contact
mr 360
New User
create contact using postman documents is here,if exist pls tell me,
postman request(json) and response is here ,if exist pls send me
What?
3cx with postman rest api documents is available here?
There's no API for now. Coming in a future update of V18.
You need to create a contact where? In your CRM or the 3CX Phonebook?
You can use the O365 Integration or the CRM Integration for now
I think create contact details external wise(postman or others),how is it possible ,tell me sir,
i create contact using via 3cx dashboard ,another way for creating contact api
lastshadow
