Crestron Rava
mammet.zada
Dear All
Please could you say me that how can I add Crestron touch panel TSW760 to 3CX .
I already configured 3cx side and tested for chrome extension , normally operated.
But I would like set up Touch panel to system. Which parameters should be write there I don't know. I try something but get nothing.
Username and password should be the Auth ID/Pass. The rest seems good. Check for more settings with codecs, headers and such because you'll need them to make the unit work perfectly (if even).
I cant find all parameters from 3CX side for filling Crestron touch panell. Could you please say me your advise for proper set 3cx and find needed parameters for touch panel
Please attach screenshots of the panel UI, I'll try to point you in the right direction!
I think he wanted screenshots of the Crestron unit GUI.
Please see screen shot from Crestron UI, Now I reset it to factory settings. But in the first post I attached last configuration. WhatsApp Image 2020-04-15 at 21.36.25.jpeg
Run wireshark on the server.
Put the extension info back in and save.
Go back to Wireshark. Stop the trace. See what it tells you about the transaction between the Crestron and 3cx.
Please do you know where can I find SIP server realm in 3CX ?
I think Realm can remain blank - it hasn't been part of 3cx for 6 years.
I kindly ask you check my server if you have spare time . I can forward you m credentials. because I can only use chrome extension. Mobile and windows version couldn't , also crestron UI
3K8iMGWviZ
