CRM Axonaut integration
Clément EQUINOXES
Hello, I can't find the solution for authentification API. I understand under BASIC configuration, it doesn't work with my API key.
curl -X 'GET' \
'https://axonaut.com/api/v2/[email protected]' \
-H 'accept: application/json' \
-H 'userApiKey: 11111111111111111111111111'
I think I need to put that somewere
PLease help, thanks in advance
Link to documentation of my API : https://axonaut.com/api/v2/doc
I try this but it doesn t work :
<Scenarios> <Scenario Id="LookupByEmail" Type="REST">
<Request Url="https://axonaut.com/api/v2/employees?email=" MessagePasses="0" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json">
<headers>
<accept>application/json</accept>
<userApiKey>[APIkey]</userApiKey>
</headers>
</Request>
Same Error
<headers>
</headers>
</Request>
Same Error
This is how you should specify it:
XML:
    <Headers>
        <Value Key="userApiKey">[APIkey]</Value>
    </Headers>
</Request>
Thanks a lot, it seems to work but, next problem :
It say on a first message that the link with the API is working but the number doesn't exist and "check th log".
On a second message, it say "Result obtained"
- I try to call with this number and he doesn't find the contact
- During the test if i put the number without "." between numbers, it give me the same first message but no "Result obtained"
- I re-imported the xml in the CRM tool software before I had error with API and now, no error but nothing appear
I'm close but I don't know what to do
thanks in advance
Maybe it will help, the API doc say that :
"id": 55,
"gender": 1,
"firstname": "Claire",
"lastname": "Rousseau",
"email": "[email protected]",
"phone_number": "0102030405",
"cellphone_number": "0605040302",
"job": "CEO",
"is_billing_contact": true,
"company_id": 33,
"custom_fields": {
"myCustomField": 1
and this the URL to reach API : https://axonaut.com/api/v2/employees?phone=0612345678
I change "0612345678" by [Number] and I am a bit lost after
I try employees.id ??? I don't know, maybe the problem come from that
Thanks in advance
My XML files, if it helps
When you map the JSON response to variables, why are you specifying "employees"?
The JSON response doesn't have any "employees" node:
JSON:
      "id":55,
      "gender":1,
      "firstname":"Claire",
      "lastname":"Rousseau",
      "email":"[email protected]",
      "phone_number":"0102030405",
      "cellphone_number":"0605040302",
      "job":"CEO",
      "is_billing_contact":true,
      "company_id":33,
      "custom_fields":{
         "myCustomField":1
Good morning,
Did you manage to get the coupling with axonaut to work?
I'm trying to do it myself.
Thanks in advance
ARKC
