CRM doesn't popping up
mostafa_amiri
Hi..
We already use the latest version of 3cx and wrote our own CRM integration. It's already lookup the calling number but the CRM contact url does not popping up..
I already checked the integration and there's not problem on template which is made by us but don't know how to fix the problem.
PS: Our integration is 16.0.4.493 version but it's not working on 16.0.6.641. I also tested that with and without chrome extension but there's no difference on the results..
Regards,
First, check if contacts are being added to the 3CX Console > Advanced > Contacts, when they call in. If you don't see these contacts being added, then you need to enable verbose logs in 3CX and then make a call to reproduce the issue and check the 3cxSystemService.log file.
If contacts are added, you need to check if the Web Client shows the contact button:
If you see this button, it's probably the browser blocking popups. You need to allow popups from the Web Client URL.
I am having this issue also after latest update, 16.0.641 . Contacts are updating in 3CX, but the little rolodex icon is not showing up for incoming calls.
I have the same problem.. Contacts are updating and added to Contacts Console but the little rolodex icon didn't show up.. Any chance to solve this problem?
Regards,
awan05
