CRM Imported contact company name not showing
ThomasV2
Platinum Partner
Hi All,
We've created an import for our CRM system with a custom template.
Everything works as expected.
Some imported contacts however, do not show the Company field in detail view.
When looking at the whole contact list, the company name is present. It's only empty when opening the contact.
Are there restrictions in the company name field characters? In the case i'm looking at, the string is 60 char long and has a forward slash in the name.
See screenshots for examples
The company name field should not have more than 50 characters. If you edit the field from the console, you will notice that it will not let you enter more than 50 characters.
costionofrei
