CRM Integration, condition
Simone Rota
Forum User
is it possible put a condition in CRM integration?
Ex:
If Contact.FirstNale="XXX"
<Variable Name="FirstName" Path="contact.CompanyName">
else
<Variable Name="FirstName" Path="contact.FirstName">
Simone Rota
You'll want to do this:
XML:
<Variable Name="CompanyName" Path="contact.CompanyName">
  <Filter />
</Variable>
  <Filter />
</Variable>
Then, in the Output section:
XML:
<Output Type="FirstName" Passes="0" Value="[IIf([FirstName]==&quot;&quot;,[CompanyName],[FirstName])]" />
Change the &quot;&quot; (empty text) to whatever to need to compare with. Example: &quot;XXX&quot;.
arneg
